Best and Maximum height AP277 -AP275
Hello Team,
Can anyone please help me to understand what is the maximum  and the best reccomended height for AP277 and AP255.
For example if i install them at 10 meter a mobile phone will be able to receive good signal but will be ableto reach back the access point ?
Thank you
Re: Best and Maximum height AP277 -AP275
10m is fine for AP height for both the 275 and 277. Over 10m, with the 277, you will want to downtil the 277 5 deg for every 5m above 10m (so if you install at 20m AGL, you would need to downtilt 10deg)
Jerrod Howard
Thanks for your response but will the signal from a mobile phone be able to reach the AP that is in 10 or 20 meter height because the antenna from the mobile is not so powerfull. If i install them in 3 meter height will i have any issues ? Thank you again
10m height is fine, 20m will work but signal will be slightly less. Yes a mobile phone will work. I routinely do testing from a 275 out to 200m and still have string signal. For 277, if you wall mount or pole mount the directional, at 20m you would want 10deg of downtilt.
Jerrod Howard
Hello, If i place them in less than 10 meters height for example 3meter will be fine ? or will i have any issues ? Because i want also to have high density not only coverage and if i place them too high the cell going to big. Thank you.
3-10m AGL is fine.
Jerrod Howard
Frequent Contributor I
Hi All,
What about the height for AP-365 as this AP have builtin Omni-directional Antennas. The buildings height where we are going to deploy these APs are around 13 meters.
At that height, if you are looking for HD coverage, then 277 is better. If user count will be 50 or less, 367 will be fine. What is the evironment, total users in the area, etc?
Jerrod Howard
We need to install a WAP in our client warehouse at 15 meters high and we need to make it an outdoor unit due to the high temperature since it's near the ceiling. Kindly advise what is the approximate safe radius at 15 meters height to connect 12-19 WAP which depends on the radius that you would suggest.
John UAE
I would start a new thread and define what you mean by connecting WAPs to the AP on the ceiling?
Jerrod Howard
