Best auth mode
Hi
i have an new building with some med carts  , and i need to configure my 7205 controller with my AP 205
i would like to know what is the recommended way of authentication and also the easiest to configure
( in the past i had cert server and radius...it wasnt easy to manage it , this is why i am looking for other way to connect
thanks
TK
Re: Best auth mode
You should use whatever authentication methods are recommended by the Med Cart manufacturer.  What is the operating system?
Re: Best auth mode
Also, consider working with your Aruba partner to design an authentication architecture that works across platforms and is easy to manage.
Tim Cappalli | Aruba Security
Re: Best auth mode
Hi
80% are windows 7 and few still old XP machines , all of them are at workgroup , not join to a domain
if i would like to use LDAP do i need another server like radius , or i could use only the controler ?
thanks
Re: Best auth mode
If they are not joined to the domain, it is going to be painful to configure all of those computers.  You probably can only do WPA2-AES-PSK
Re: Best auth mode
Hi
so the only way is with user/password ? (local db)
Re: Best auth mode
How many carts do you have?  It is difficult to configure carts for username and password authentication if they are not part of a domain...
Re: Best auth mode
i have a round 100 carts
its not a problem to get one by one , i will do it step by step
i saw that i can run LDAP , if i will create each cart a user on the AD do i need anything more ?
Re: Best auth mode
 Using LDAP will force you to install custom software on each cart.  I would engage a consultant to tell you the best way to deploy all of your carts.  I can tell you what you should do, but a consultant will work directly with you to make sure that everything is considered.
