Occasional Contributor I
Best practice documentation avail for # of concurrent users -per AP 65 and 105 please?
Realize there are many variables here (Applications used...etc) but are there any Best practice documentation avail for # of concurrent users -per AP 65 and 105 please
Re: Best practice documentation avail for # of concurrent users -per AP 65 and 105 please?
not really... it depends on what you are doign with your wifi...
Suppose that if you got a ap 65 i wouldnt put more than 8 users per band on that AP if im using VOIP
let say for the AP 105 voip  maybe 20 on 5ghz? and 15 on 2.4ghz? it just depends... we really cant say it
Cheers
Carlos
Alternetworks Corp
Thank you for response as I realize this is a very generic question and I thank you for your response.
Much appreicated.
