Best practice for laptop nic cards
what are some of your recommended setting on your laptop network adapters for a enterprise environment.
example: roaming aggressiveness, throughput booster, transmit power , preferred band
#AirheadsMobile
Re: Best practice for laptop nic cards
You should stick with the defaults.
It is not practical to have to set all of these settings manually. The system should be tuned to benefit all devices without having to resort to per-client settings.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
