Contributor II
Best way to Controller Firmware Upgrade? 다중 구성의 컨트롤러 펌웨어 업그레이드 방법?
안녕하세요.
약 1300 대의 AP로 구성된 사이트에서
컨트롤러 4대의 펌웨어 업그레이드시 가장 서비스에 영향이
없도록 업그레이드 하는 방법은 어떤 방법일까요?
어떤 순서로 업그레이드 하면 될까요?
[ENG]
We are upgrading the firmware to the operating company with the following configuration.
In what order do you prefer to proceed with the upgrade?
Customers want to minimize service interruption.
Master 1EA, Local 3EA   HA & VRRP Configed.
Phyical
Master : Backup LMS
Local1 : AP 300EA  LMS Local1, Backup LMS Master
Local2 : AP 400EA  LMS Local2, Backup LMS Master
Local3 : AP 500EA, LMS Local3, Backup LMS Master
Contributor II
RE: Best way to Controller Firmware Upgrade? 다중 구성의 컨트롤러 펌웨어 업그레이드 방법?
I understand that it is recommended to reboot sequentially after OS upload.
The following information is recommended for OS release notes.
Thank you.
Upgrading in a Multicontroller Network
In a multicontroller network (a network with two or more Aruba controllers), special care must be taken to upgrade all controllers based on the controller type (master or local).
Be sure to back up all controllers being upgraded, as described in Backing up Critical Data on page 17.
For proper operation, all controllers in the network must be upgraded with the same version of ArubaOS software.
For redundant (VRRP) environments, the controllers should be of the same model.
To upgrade an existing multicontroller system to this version of ArubaOS:
1. Load the software image onto all controllers (including redundant master controllers).
2. If all the controllers cannot be upgraded with the same software image and rebooted simultaneously, use the following guidelines:
a. Upgrade the software image on all the controllers. Reboot the master controller.
After the master controller completes rebooting, you can reboot the local controllers simultaneously.
b. Verify that the master and all local controllers are upgraded properly.
