BlackListing APs
  • 1.  BlackListing APs
    Posted Aug 27, 2013 07:05 AM
    Is there an option to BlackList APs as you would to clients?
    For example an organisation is purchasing some of our APs and what I'm looking to do is prevent them from connecting the APs onto our switches.
    Many thanks,
    H
  • 2.  RE: BlackListing APs
    Posted Aug 27, 2013 07:12 AM
    That is exactly what the Control Plane Security Feature does.
  • 3.  RE: BlackListing APs
    Posted Aug 27, 2013 02:47 PM
    Hello.
    I'm not sure what you mean 'connecting onto switches'.
    As cjoseph wrote, you can use Control Plane Security feature to authorize APs to connect to your Aruba controller.
    Or if you mean connecting APs to wired switch, you can use 802.1x on switch for authorization your APs (wpa supplicant on AP). You can setup it on provisioning page.
    Regards
    Jaroslav
  • 4.  RE: BlackListing APs
    Posted Aug 28, 2013 03:23 AM
    Many thanks guys!
