Blacklisted Android devices
  • 1.  Blacklisted Android devices
    Posted Apr 23, 2014 11:36 AM
    I have to, from time to time, blacklist android devices.
    I've noticed they only stay blacklisted for 60 minutes even though my setting on the controller is permanent and other devices are blacklisted correctly.
    Anyone experienced this?
    Running ArubaOS 6.2.1.5 and 6.1.3.10
  • 2.  RE: Blacklisted Android devices
    Posted Apr 23, 2014 11:42 AM
    Can you show the output of "show ap blacklist-time" ?
  • 3.  RE: Blacklisted Android devices
    Posted Apr 23, 2014 11:54 AM
    scoaker1,
    If you blacklist a device that is currently connected to the controller, it will be blacklisted for the "Blacklist Time" in the Virtual AP that it was connected to.  If you first disconnect it, then blacklist it, it will be blacklisted for the blacklist time that Tcapalli mentioned above.
  • 4.  RE: Blacklisted Android devices
    Posted Apr 23, 2014 12:17 PM
    I have noticed that in the GUI, the blacklist time is set to 0 for the VAPs in question,
    However, when I go to the cli, this is reported.
    (HHS_Aruba3400) #show ap blacklist-time
    ap blacklist-time:3600
    All devices but the Androids are permanently blacklisted.
    Enclosed is a screen shot of a few blacklisted clients.
