Frequent Contributor I
Block SSID broadcasting from Apple Device
Current Setup:
3400 controller running 6.4.1.0
RF Protect licensing
38 AP's
2 Air Monitors
Configured a WIP policy to block particular SSID's coming from numerous Apple devices(mobile hotspot).  Wireless containment is enabled and setup as deauth only
Is the default behavior for all clients to not be able to connect to the defined SSID at all? or connect/disconnect continuously?  the air monitor(s) are in great range of the suspected device broadcasting the SSID I want to block.
Re: Block SSID broadcasting from Apple Device
Yes, clients should not be able to connect. Keep in mind that if they're not broadcasting your corporate SSIDs on their personal devices, deauthing clients can be interpreted as illegal (US).
Tim Cappalli | Aruba Security
ok.  how can I remove an ap group from the default WIP policy?  its greyed out.
