Block Traceroute and allow ICMP
hi,
i need to block traceroute to the local ressources , and in the same time in need to allow ping to foreing server any idea
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Block Traceroute and allow ICMP
See if this helps you:
http://community.arubanetworks.com/t5/Community-Tribal-Knowledge-Base/ICMP-Type-and-Code-Filtering/ta-p/16211
Thank you
Victor Fabian
Lead Mobility Architect
yrs it was
thank you
Raouf CHAHBOUNE
how extended ACL works ??
Raouf CHAHBOUNE
Can this be done on Instant?
No, because you cannot block ICMP by type on instant.
Colin Joseph
Aruba Customer Engineering
Thanks Colin,
To block traceroute I've added a deny udp 33434-33534 rule and it appears to work fine.
