Contributor I
Block torrent
Hi Forum,
I want to block torrent and facebook in my network. Please tell me that how can I block them, torrent changes its ports/IPs randomly & facebook also has much IPs to access. Is there any way to block torrent & facebook.
Help me
Faisal
Re: Block torrent
We cannot specifically block torrent traffic at this time.
There is a way that you can create a named ACL *.facebook.com and block traffic to that, but that is no guarantee facebook uses other URLs for data.  You would need a content filter for that.
Frequent Contributor II
Re: Block torrent
We had a problem with students using torrents on our school wireless network. We actually recieved notification that someone was pirating movies from our wireless network. I discovered then that we couldn't block torrents due to its rotating random ports.
After a little research I found out that most (not all) torrent programs reach out and touch on a set of default ports first before they started to rotate to other random ports. Said ports are tcp 6881-6889. So I created a policy that blocked those ports and then black listed the device.
It wasn't a perfect solution and I did "catch" a few legit users but for the most part it did the trick as black listed users had to come to IT services department to get taken off the list.
I hope this can help you!!
Scott McNeil - Sr. Network & Security Engineer, Global Process Automation
Network+ | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
