Bridge mode not avaliable on VMC (VMware) Web Interface
I´m trying to understand why fordward-mode bridge is not avaliable on the web interface (blank). At the CLI is working perfectly.
wlan ssid-profile "01"
    essid "01"
    opmode wpa2-aes
wlan virtual-ap "01"
    aaa-profile "01"
    vlan 2972
    forward-mode bridge
    ssid-profile "01"
Also, there are SSIDs on CLI that are no present on Web interface.
Re: Bridge mode not avaliable on VMC (VMware) Web Interface
I deployed a new VM and got the same issue.
Bridge SSIDs are deprecated on controllers and can only be configured through CLI for backward compatibility reasons.
This is a capture from a 8.2.1.0 VMC that shows bridge mode available through web GUI.
gvala,
Did you change anythging on VMC that would have changed this behavior?
I have installed 3 time (including PoCs) and got the same issue. No bridge mode. Just on CLI.
Just upgraded from 8.2.0.2. Nothing else.
This option shows up when i tried to edit the WLAN. The drop down menu has four options: Tunneled, unencrypted tunnel, bridged and split-tunnel.
I don't know what happens if i try to create a new WLAN because in this case I get a message that says that a PEF license is needed to add a WLAN
I´ve just upgraded the VMC.
Creating a WLAN requires a PEF license. Please verify that PEF license is installed and active
Is PEF license required for creating WLAN? Is thar right?
I thought LIC-AP would be enough.
MVP
@Herman Robers
Hi Herman,
I hadn't heard of that so went to chec some release notes.
From the AOS 8.2.1.0 RN:
"Support for WLAN Forwarding Mode Options
Starting from ArubaOS 8.2.1.0, new options, Split-Tunnel and Bridge, are added to the Forwarding mode drop-down list in the WLANs > General
page."
Can I conclude that bridge will still be supported going forward?  Or are we talking about something different here?
Could you check and comment please?
Koen (ACMX #351 | ACDX #547 | ACCP)
