Occasional Contributor I
Bridgemode SSID and Brocade FCX
I have a customer that wants to do a Bridgemode SSID for one of their VAPs. I understand the way to accomplish this on the edge switch is to have the port in trunk mode and the VLAN the AP is getting its IP address from be the native VLAN on the trunk. I am not familiar with Brocade switches, but it appears that you must change the default VLAN to accomplish this. Does anyone have a switchport config example doing Bridgemode with a Brocade switch?
