Broadcast / Multicast traffic is dropped from Wired to Wireless on Bridged SSID with 7005 controller
Hi!
We are experiencing the following problem:
Some Broadcast / Multicast traffic is being filtered from Wired to Wireless (and vice versa) on a bridged SSID. We are using a Aruba 7005 controller and a Aruba 325 Access Point. When looking at the "show configuration" it shows no broadcast arp under the VAP config. But it seems that the Access Point is still filtering some Broadcast/Multicast traffic, because packets to and from for example a sonos music system or google chrome cast are not going through.
Does somebody have an idea on how to disable broadcast filtering completely on a bridged SSID?
Cedric.
