Contributor I
Broadcasting an SSID
I have a newbie question.  How can you tell from the controller if your ssid is being broadcast?  Thanks.
Re: Broadcasting an SSID
Dashboard> WLANs
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Contributor I
I actually needed to find where to hide the SSID.  I found it in Configuration
