Contributor II
Built in antennas in an AP275
In the AP275, In a little confused by the definition of the Omni directional 3x3:3.  There are 6 built in omnis.  I assume three are for the 2.4 and three are 5 ghz..  Are all 6 three-pole, such as 2H and 1V?
Re: Built in antennas in an AP275
3 omnis antenna are 2.4 GHz (2 are V polarized and 1 is H polarized)
3 omnis antenna are 5 GHz (2 are H polarized and 1 is V polarized)
