cdj
Contributor I
Bypassing Captive Portal for Specific Users
Is there a way to bypass the captive portal authentication for guest users? Can I configure a whitelist for specific users to bypass the captive portal?
MVP
Re: Bypassing Captive Portal for Specific Users
You can use user derivation rules to give different user-role by mac-address
You can use server derivation rules to give different roles based on user (internal dbase) or radius/ldap attributes for external servers.
Or if you should have clearpass the possibilities are endless. :)
Koen (ACMX #351 | ACDX #547 | ACCP)
