Frequent Contributor II
C-Build Upgrade Issues
I tftp'ed a patch AOS ver to the controller (3400).  The AOS C_ArubaOS_MMC_6.1.3.5_36216 shows up in flash via the "dir" command:
-rw-r--r-- 1 root root 40384000 Dec 7 13:32 C_ArubaOS_MMC_6.1.3.5_36216
-rw-r--r-- 1 root root 17078 Dec 8 21:08 default.cfg
-rw-r--r-- 2 root root 9112 Oct 26 12:20 default.cfg.2012-10-26_20-20-00
drwxr-xr-x 3 root root 1024 Sep 10 07:44 fieldCerts
-rw-r--r-- 2 root root 9112 Oct 26 12:20 original.cfg
-rw-r--r-- 1 root nogroup 3047425 Dec 7 07:26 post.data
-rw-r--r-- 1 root nogroup 17078 Dec 7 07:15 startup
drwx------ 2 root root 1024 Sep 10 07:43 tpm
But not on either partition 0 or 1
(SF-Aruba-Master) #show image version
Partition : 0:0 (/dev/hda1)
Software Version : ArubaOS 6.1.3.1 (Digitally Signed - Production Build)
Build number : 32786
Label : 32786
Built on : Tue Mar 13 00:28:42 PDT 2012
Partition : 0:1 (/dev/hda2) **Default boot**
Label : 32786
In addition the show storage command does not reveal hda1 or 2.
(SF-Aruba-Master) #show storage
Filesystem Size Used Available Use% Mounted on
none 300.0M 2.3M 297.7M 1% /tmp
/dev/hda3 200.6M 93.5M 96.8M 49% /flash
So, how do I get the controller to boot  C_ArubaOS_MMC_6.1.3.5_36216?
rafael
Re: C-Build Upgrade Issues
Seems it didnt upload correctly...
Did you try uploading it again to the partition 0/0?
It should appear on show image verion otherwise it wont boot from that firmware you uploading...
It has happened to me that i try to upload the image but then it seems that it didnt upload so i try again and it works...
When that happened never checked the dirs... so i dont know if its the same problem...
But as long as you got your backups and also you dont touch the partition 0:1 you should be fine to try it again on the partition 0:0
Alternetworks Corp
Label : 32786
Label : 32786
rafael
You need to upload it using Maintenence> Image Management> , NOT Copy Files...    "Copy files" copies it like a regular file, NOT a system image.
Maybe he FTP or TFTP the file using the image managment to upgarde it... i have done it with no issue to upgrade.
Also it has happened to me but really really unusual that i try to upload it for example uploading the file via browsing  and i get the same situation of him that i dont see the image on the show image but i have not verified if its on the dir.... so i dont know if its the same case...
And when that happens i just try again and well it works.
Though never happened when upgrading it with the TFTP.
Cheers
Carlos
Alternetworks Corp
If you use Image Management to upgrade, it NEVER shows up when you type "DIR"
Well then i have not said anything :)
Alternetworks Corp
Thanks everyone.  It seems that I should use the GUI?  Ok...
Thanks everyone.  It seems that I should use the GUI?  Ok, I'll give it a whirl.
Rafael
Re: Thanks everyone. It seems that I should use the GUI? Ok...
Or... if you use the commandline, the format is:
copy tftp: <ip address> <filename> system: partion 1 or 2
well, when i tftp'd it originally I did use the copy tftp:addr filename system:partition 1
but it ended up in flash....
rafael
Its not letting me do the following via cli:
(SF-Aruba-Master) #copy tftp: 192.168.151.20 C_ArubaOS_MMC_6.1.3.5_36216 system: partition 0:0
% Invalid input detected at '^' marker.
(SF-Aruba-Master) #copy tftp: 192.168.151.20 C_ArubaOS_MMC_6.1.3.5_36216 system: partition 0:1
___
(SF-Aruba-Master) #copy tftp: 192.168.151.20 C_ArubaOS_MMC_6.1.3.5_36216 system: partition 0/1
(SF-Aruba-Master) #copy tftp: 192.168.151.20 C_ArubaOS_MMC_6.1.3.5_36216 system: partition 0/0
(SF-Aruba-Master) #copy tftp: 192.168.151.20 C_ArubaOS_MMC_6.1.3.5_36216 system: partition 0?
0 Partition 0
<cr>
When I ask it what is wants to use it says:
(SF-Aruba-Master) #copy tftp: 192.168.151.20 C_ArubaOS_MMC_6.1.3.5_36216 system: partition ?
0 Partition 0
1 Partition 1
<cr>
but I think that is what i already tried that ended up with the image in flash...
rafael
