CA
In windows 2008 & Higher version there is no option to igonre CA certificate .
So how should we proceed to solution ?
Re: CA
Windows Server or Client?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: CA
Windows Client ..& Ubuntu 18
Re: CA
There is no Windows 2008 Client.  I am not familiar with Ubuntu.  Why would you want to ignore the CA?
Re: CA
don't know if you can ignore the certificate, but you can choose not to validate a server cert when connecting to a PEAP or TLS SSID. The certs are part of the standard, even if you just accept the self-signed certs presented on a demo or test SSID.
I don't have a Win8 laptop handy to test with, but maybe someone else can.
Jerrod Howard
