Contributor II
CAP Bridge Mode with forward mode Accsee
Hi Guys,
I found a interesting thing about CAP bridge mode with forward mode access.
When I set the forward mode into access, the AP still gives the clients' packets a 802.1q tag。
I think this is how the ap distinguish the packets, if not the AP would never know the packet is sent to the AP or the client.
Am I wrong?
Re: CAP Bridge Mode with forward mode Accsee
Many bridge mode deployments will have the AP and client traffic on different VLANs.
Tim Cappalli | Aruba Security
Contributor II
I'm just curious.
I set the switchport mode into access, and set the vlan to the same vlan as the AP's.
I thought it would work, because the AP and the STA have the different MAC address, the AP should know how to distinguish the packet. But the fact is that all the packets from the STA AP always sets a 802.1q tag in the front and the 802.1q tag belongs to the AP's vlan.
The switch side will strip dot1Q header on an access port.
Sent from Mail for Windows 10
Contributor II
If the switch's port is set to access, then the switch will simply drop the packet with 802.1q tag.
Only trunk port will stip the 802.1q tag.
What kind of switch? Cisco switches will accept tagged traffic on an access port as long as it’s the same VLAN ID as the access VLAN.
Contributor II
S2500-48P MAS
Can’t test this right now. If it is urgent, please contact Aruba TAC.
Contributor II
I just want to understand the basic concept, and want to make sure what I did was right.
