mom
Contributor II
CAP/RAP CLI traceroute
Hi all!
Is it possible to do a traceroute from a CAP or RAP CLI?
Thank you!
Best regards
Matthias
Re: CAP/RAP CLI traceroute
Hey, you can perform a traceroute from the AP if you have a console cabkle attached. You will need to break the prompt (esc + ctrl + k)
~ # Switching to Full Access
~ # traceroute 8.8.8.8
traceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 38 byte packets
 1  ** *
The above may also be possible if you have Telnet enabled in the AP System Profile and also via the Backup ESSID.
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
mom
Contributor II
Hi!
Thank you, works....
Best regards
Matthias
