Contributor II
CAP vs RAP licences limitations.
Hi everyone,
Here is our situation: We are currently testing the Aruba system for our company. We are planning to need near 200 AP. We have like 20 to 23 offices in an MPLS network. Some smaller and some bigger one.
We are planning to have 2 x 3400 controllers. They will each be install in an major separate office. The master will act has a Local too (with AP on him). I know that this is not best practice but we think that it will be ok.
So here is my thought about it : Normally, we would use Campus AP because we are on our secure network. But due to limited licences (64 CAP), we will need to add RAP.
So for offices 1 and 2 who have Master and Local controller, I’ll use CAP. We are talking about 15-20 AP for both. For other AP, I'll use RAP. I want to split the charge between the 2 controllers. Like 10 CAP and 90 RAP each. I know that for RAP, they have increased support on 3400 (256 RAP) because we expect an RAP to use less resource (split-tunnel or Bridge). And it' exactly what we want to do.
For all the AP, we will provide 2 SSID. One public and the other for the enterprise network. Almost each office have their Public network directly at the office. And of course the enterprise network too. So we will use basically only Bridge mode. So less resources needed on the controller.
Is that all that I wrote seem feasible? Any one see something that won't work? Or something wrong. Feel free to challenge me !
I'm already aware that we have no backup for the master. And like i said before, yes we plan to use the master for AP connection. And if one controller fails, all the AP wills failover the other one.
We already talked about adding 1 or 2 controllers if needed to spread the load. But only if it's really needed.
Thanks.
Re: CAP vs RAP licences limitations.
guillaume.royer@cima.ca wrote:
Hi everyone,
Thanks.
Unfortunately, even though the CAPACITY of a 3400 is 256 RAPs, each RAP will need an AP license.  Also, if you have 64 CAPs on a 3400, there is no more CAPACITY for any RAPs.
Contributor II
Sounds good for the RAP licences.
How it's working for the CAP capacity ? If we have 63 CAP, we can then configure 200+ RAP ?
for 3400 if you have 63 CAPs then you can have a naximum of 4x RAPs (1:4) ratio
Contributor II
And is that a limitation or only a recommanded number of AP ?
The system will block my if I want to add 65 CAP ? Or I'll be able to but not recommanded ?
I have kind of same issue just need to know that after Aruba OS 6.3 (centralize licensing) CAP/ RAP limit for 3400 Series is how much ....as per present Mobility Matrix it is 64 CAP & 256 RAP.
Kindly help in the understanding.
Thanks & Regards,
Pushkar
Trusted Contributor I
the whole 1:4 system has gone out of the windows since 6.2 (or 6.3 not sure). RAP = AP, the limit is the limit, afterwards it will just not work.
Frequent Contributor I
Not sure this is the case... from my 3200 controller running 6.3.1.9, looks like i still have a 1cap:4rap ratio.
(3200) #show ap license-usage
AP Licenses
Type                      Number
AP Licenses               128
RF Protect Licenses       123
PEF Licenses              128
Overall AP License Limit  123
AP Usage
Type             Count
Active CAPs      6
Standby CAPs     0
RAPs             0
Remote-node APs  0
Tunneled nodes   0
Total APs        6
Remaining AP Capacity
Type  Number
CAPs  26
RAPs  104
(3200) #show ver
ArubaOS (MODEL: Aruba3200-US), Version 6.3.1.9
Website: http://www.arubanetworks.com
Copyright (c) 2002-2014, Aruba Networks, Inc.
Compiled on 2014-07-15 at 12:04:41 PDT (build 44832) by p4build
ROM: System Bootstrap, Version CPBoot 1.1.4.0 (build 16250)
Built: 2007-09-20 16:14:24
Built by: p4build@re_client_16250
Switch uptime is 9 days 8 hours 46 minutes 17 seconds
Reboot Cause: User reboot (Intent:cause:register 78:86:0)
Supervisor Card
Processor XLR 508 (revision B2) with 1187M bytes of memory.
32K bytes of non-volatile configuration memory.
512M bytes of Supervisor Card System flash (model=CF 512MB).
(3200) #
interesting, my 650 doesnt show the same, it is the 1:1 like i expected. version 6.3.1.6.
does the GUI show the same james?
(Aruba650) #show ap license-usage
AP Licenses
Type                      Number
AP Licenses               8
RF Protect Licenses       8
PEF Licenses              8
Overall AP License Limit  8
AP Usage
Type             Count
Active CAPs      0
Standby CAPs     0
RAPs             0
Remote-node APs  0
Tunneled nodes   0
Total APs        0
Type  Number
CAPs  8
RAPs  8
anyone from Aruba that can comment on what james sees?
