Hi Experts,
As a newbie i have tried metageek inssid free tool to check the spectrum . In the result it shows co-channel interference .Does it mean the ap which we deployed  making interference.
In aruba controller is there a way to see the intreference device ?
Thank you
On the controller, you can see RF utilization on the dashboard, as well as interferring WLAN devices.  It does not separate out which devices are causing what part of the interference, however.  If you have the RF protect license, you can turn on Spectrum Monitoring to see non-wifi devices that are causing interference.
Colin Joseph
Aruba Customer Engineering
