CLI Command for Ethernet AP Stats
Hello Everyone
I need to check if some APs are incrementing errors on the ethernet port.
Is there any command to verify it ?
Regards
Thiago
Re: CLI Command for Ethernet AP Stats
Unfortunately no, all you can see is the following :
(MASTER_CONTROLLER) #show ap debug port status ap-name test
AP "test" Port Status
Port MAC Type Forward Mode Admin Oper Speed Duplex 802.3az PoE STP TX-Packets TX-Bytes RX-Packets RX-Bytes
0 24:de:45:12:ce:2b GE N/A enabled up 1 Gb/s full N/A N/A N/A 968132 326820777 5071733 709857492
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Do you have access to the switch side of the link?
Sent from Windows Mail
Tim Cappalli | Aruba Security
Yes in this case i have access to the switch were the aps are connected, and i´m able to verify it by switch cli, but in some cases i´m unable to access the switch.
Anyway, appreciate the help
Try:
show ap debug system-status ap-name <ap-name>
