CLI command for POE to power up the IAP-135?
Currently, I am doing a setup with a Aruba A620 controller and a IAP-135.
The PoE port of the controller is connected to the ENET0 port of IAP-135.
However, the controller did not power up the IAP-135.
What is the CLI command to power up?
Please advise.
MVP
Re: CLI command for POE to power up the IAP-135?
1.only the 4 ports at the bottom got poe support.
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/620-maximum-PoE-ports/td-p/30718
2.When (and if) you "factory defaulted", did you use "write erase all" or just "write erase"?  The "write erase all" command erases the licenses.  There is a license on all 6xx series controllers that enables PoE.  If you deleted this, you will need to call support and get it re-enabled (or import the previous licenses that you backed up before you erased them).
Super Contributor I
show license to see if you have Poe license loaded?
Normal Guy
MVP
yep,after enable
just show lic
Thanks kdisc98,
I unintentionally write erase all (removed all licences).
I have already resolved this issue. Thanks
