I did some searching to see if a topic exists on this but unfortunately terms like "IP address" and "config" are as common as "if" and "or" in network forums. I recently reset my controller, and after some drama got into its configuration setup via console cable (thanks jfernyc).
It seems that mid setup I misconfigured the IP address as I am unable to access the Web GUI. Pings fail. I have the GbE Link/Act port 8 connected to my switch and have lights above the connectors, so layer 1 is solid.
I am referring to some commands in the ArubaOS 6.1 CLI Reference Guide and I found what I think is the answer to my question, but I am having trouble with the syntax, or its not the right one for my mobility controller.
the bookmark for the command "interface mgmt" is what I am looking at. I log into my controller, enable, and then conf t to get to configure mode.
I have tried
(config) #interface mgmt
plus whatever settings but I always get the carat under the 'm' in mgmt, meaining thats where the syntax error lies. i cant find any answer as to why however. interface ? yields the option listing, one of which is "mgmt" but its not working.
(host) (config) #interface mgmt
ip address 10.1.1.1 255.255.255.0
that is the example syntax as quoted in the ref guide, and I think its what I'm looking for, which again, is to change the IP and Subnet of my Wireless Mobility controller. at the end of the 'interfece mgmt' section of the Ref Guide, it says that this command is for mobility 6000 controllers... so that may be why its not working, but the question remains; how to i configure my Mobility Controller's IP address via CLI?
Im using a W-620. before i reset it had 6.x on one partition, and 5.x on another.
thanks in advance for the help.
Dave.
