COnfigure WLAN wizard does nothing
When I click on Campus WLAN on the configuration tab of Aruba OS, it does nothing. I just get a grey page that says navigation panel at the bottom.
Running Aruba OS 6.4.4.6 on a 7030 controller.
This used to work, now I get nothing reguardless of browser (latest firefox and chrome) or computer (safari) I use.
Any info would be grately appreciated.
Re: COnfigure WLAN wizard does nothing
Have you upgraded recently?  Please try to clear your browser cache, or try to configure in anonymous mode in your browser.
Frequent Contributor I
I have same poroblem, tried different browser, cleaned history, reboot controller, private mode.
 6.4.4.6 - Aruba3600-US
This has been fixed in 6.5.0.0 unfortunately.
The last supported version for 3600 is 6.4.4.16 I belive which solved nothing for me. Is 6.5 doable on 3600?
The 3600 controller will only support up to ArubaOS 6.4.x
http://www.arubanetworks.com/support-services/end-of-life/#MobilityControllers
These browsers are supported by 6.4.4.16 so try one of these.
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
I checked again and it worked. Thx
Glad to hear it :D
ACMA, ACMP, ACSA
