Contributor II
CPPM - Role Mapping to Device Group
We have CPPM as our Raduis server in amix enviroment (Campus AP and IAP). Within CPPM, we have a created a device group that define all of the IAP (via ip address) on our network. I was wondering, is there a way to build a role map that points to the "device Group" that we place all the IAP in? My reasoning for wanting to do this is that we have a 802.1x services within CPPM for Machin Authentication. I want to apply a different enforcement profile to all IAP Machine Auth vs AP (campus) Machine Auth.
Thnx.
Re: CPPM - Role Mapping to Device Group
Tim Cappalli | Aruba Security
Contributor II
Thanks. I will give that a try.
I am having close to the same problem. I tried your solution and i get an error. Here is the screenshot. Am I missing a step? CPPM 6.2.6
thanks!
That was just an example. Use the name of your device group.
Oh.. gotcha, makes sense and it worked.
thanks!
