Contributor II
CPPM auth for Aironet Captive Portal
i'm using an Autonomous Aironet 1700 AP, is it possible to use the aironet's Captive Portal while using clearpass guest user credentials? i already pointed ths AP to cppm as RADIUS. what could be the best cppm service to configure?
thank you very much
#AirheadsMobile
