Contributor II
CPPm Guest Portal + controller Internaldb
greetings,
is it possible to integrate CPPm guest portal + internal db as auth server? im using controller without PEF license.
TIA
Re: CPPm Guest Portal + controller Internaldb
Technically you could, but that would completely defeat the point of using ClearPass.
Tim Cappalli | Aruba Security
