Frequent Contributor I
CPSec communication to master controller
We are planning to enable CPSec for a customer, they have a VRRP Master pair and 2 local controllers running HA Fast-failover.
Currently their LMS profile and site DHCP Option 43 are pointing to the nearest local controller.
Will the APs ever need to talk to the Master controllers when we enable CPSec?
Also, is there any benefit to using factory certificates for Master->Local IPSec rather than a PSK? Would changing this across the environment require a reboot of any of the controllers and affect client traffic?
Re: CPSec communication to master controller
No the APs will not need to communicate with the master controllers in the scenarion you've described.
When you enable CPSec all the APs will reboot at least once, maybe twice, but the controllers will not require a reboot.
A certificate is more secure than a PSK.
Cheers
James
Cheers
James
