CPSec issue?
Hi All,
Scenario...
Controller running 6.4.2.5.
CPsec enabled - auto cert provisioning on
AP connect to the controller but the status in cpsec is certified-hold-factory-cert. When changing the status to certified-factory-cert the AP reboots and the status changes back to certified-hold-factory-cert!
Here's what the controller says:
May 26 11:46:49 <sapd 311020> <ERRS> |AP 94:b4:0f:c8:da:c0@xxx.xxx.xxx.xxx sapd| An internal system error has occurred at file sapd_redun.c function redun_retry_tunnel line 4461 error redun_retry_tunnel: Switching to clear. Error:RC_ERROR_ISAKMP_N_RSA_DECRYPTION_FAILED. Ipsec not successful after reboot.
May 26 11:48:14 <nanny 303086> <ERRS> |AP 94:b4:0f:c8:da:c0@xxx.xxx.xxx.xxx nanny| Process Manager (nanny) shutting down - AP will reboot!
May 26 11:49:42 <sapd 311020> <ERRS> |AP 94:b4:0f:c8:da:c0@xxx.xxx.xxx.xxx sapd| An internal system error has occurred at file sapd_redun.c function redun_retry_tunnel line 4456 error redun_retry_tunnel: Ipsec not successful to saved lms. Error:RC_ERROR_ISAKMP_N_RSA_DECRYPTION_FAILED. rebooting.
May 26 11:49:44 <nanny 303086> <ERRS> |AP 94:b4:0f:c8:da:c0@xxx.xxx.xxx.xxx nanny| Process Manager (nanny) shutting down - AP will reboot!
May 26 11:51:13 <sapd 311020> <ERRS> |AP 94:b4:0f:c8:da:c0@xxx.xxx.xxx.xxx sapd| An internal system error has occurred at file sapd_redun.c function redun_retry_tunnel line 4461 error redun_retry_tunnel: Switching to clear. Error:RC_ERROR_ISAKMP_N_RSA_DECRYPTION_FAILED. Ipsec not successful after reboot.
May 26 11:52:38 <nanny 303086> <ERRS> |AP 94:b4:0f:c8:da:c0@xxx.xxx.xxx.xxx nanny| Process Manager (nanny) shutting down - AP will reboot!
Can anyone shed light on this?
Cheers
James
Cheers
James
Re: CPSec issue?
Have also tried deleting the AP entry and rebooting the AP, the same thing occurrs.
Cheers
James
Re: CPSec issue?
JrWhitehead,
What model of access point is this?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: CPSec issue?
It's an AP225.
Cheers
James
Re: CPSec issue?
JrWhitehead,
If CPSEC never worked previously with this access point, it is looking like there is a problem with the built-in certificate on this AP.
Re: CPSec issue?
I got the same result from 2 different AP225's. Hope they're both not broken. :(
Cheers
James
Re: CPSec issue?
How many access points do you already have connected to the controller successfully with CPSEC?
Do you have a redundant configuration?
Please execute "show whitelist-db cpsec-status"
Re: CPSec issue?
None. CPSec is disabled.
We have 2 controllers in a master-standby configuration.
Cheers
James
Re: CPSec issue?
So, to be clear, you are trying to enable CPSEC with no access points connected to the controller(s), and then connecting the AP225s?
Re: CPSec issue?
Yes that's correct.
Cheers
James
