Contributor II
CSD override - Spectralink Phones
I  am currently configuring new Aruba wireless profiles for a Juniper migration. We have 8020 Spectralink phones in production and one of the recommended configuration items for these phones is the CSD Override.
This setting is in the High-Throughput Radio profile.
How am I supposed to turn this on without effecting all my other SSIDs and clients since each AP group only has one High-Throughput Radio profile?  shouldn't this be an SSID setting?
I have the Spectralink VIEW guide and have looked through the VRDs and they haven't helped. Neither has Spectralink. Has anyone configured this? A sample configuration would be excellent.
Here is the Juniper configuration that I'm trying to migrate to Aruba:
 SSID-profile vowmc ssid-name vowmc
 SSID-profile vowmc proxy-arp enable
 SSID-profile vowmc auth-fallthru last-resort
 SSID-profile vowmc wep key-index 1 key encrypted 040a59555b741a195140
 SSID-profile vowmc load-balancing-exempt enable
 SSID-profile vowmc wpa-ie cipher-tkip enable
 SSID-profile vowmc wpa-ie auth-dot1x disable
 SSID-profile vowmc rsn-ie cipher-tkip enable
 SSID-profile vowmc rsn-ie auth-dot1x disable
 SSID-profile vowmc transmit-rate 11a mandatory 6.0,12.0,24.0 disabled 48.0,54.0 beacon-rate 24.0 multicast-rate AUTO
 SSID-profile vowmc transmit-rate 11g mandatory 6.0,12.0,24.0 disabled 1.0,2.0,5.5,11.0,48.0,54.0 beacon-rate 12.0 multicast-rate AUTO
 SSID-profile vowmc attr qos-profile voice
 SSID-profile vowmc attr vlan-name vowmc
 radio-profile 1405-RP20
 radio-profile 1405-RP20 dtim-interval 5
 radio-profile 1405-RP20 rf-scanning mode passive
 radio-profile 1405-RP20 rf-scanning channel-scope operating
 radio-profile 1405-RP20 wmm-powersave enable
 radio-profile 1405-RP20 11n channel-width-na 20MHz
 radio-profile 1405-RP20 cac video mode enable
 radio-profile 1405-RP20 cac voice mode enable
 radio-profile 1405-RP20 cac voice max-utilization 45
 radio-profile 1405-RP20 cac background policing disable
 radio-profile 1405-RP20 cac best-effort policing disable
 radio-profile 1405-RP20 cac video policing disable
 radio-profile 1405-RP20 cac voice policing disable
 radio-profile 1405-RP20 SSID-profile Laptops-Tablets
 radio-profile 1405-RP20 SSID-profile vowmc
 radio-profile 1405-RP20 SSID-profile Physician
 radio-profile 1405-RP20 SSID-profile vendor-sp
 radio-profile 1405-RP20 SSID-profile Ascom
 radio-profile 1405-RP20 weighted-fair-queuing weight Laptops-Tablets 1
 radio-profile 1405-RP20 weighted-fair-queuing weight vowmc 1
 radio-profile 1405-RP20 weighted-fair-queuing weight Physician 1
 radio-profile 1405-RP20 weighted-fair-queuing weight vendor-sp 1
 radio-profile 1405-RP20 weighted-fair-queuing weight Ascom 1
-Joey
