Campus AP bridge mode not working
  • 1.  Campus AP bridge mode not working
    Posted May 19, 2016 12:30 AM
    Hi , we need to configure Campus AP to work in bridge mode, now I test it in our lab.  I use wizard to create a WLAN .(bridge mode) , but not working . Configuration as below.
    1.  on controller, create valn 2, ip address 10.1.1.1/24 , and assign port g0/0/0 to vlan 2. Also create vlan 3 on the controller, but did not assign any port to vlan 3
    2. use Wizard to create a WLAN (bridge mode) , put vlan 3
    3. create vlan 2, 3 on the switch
    4. connect controller port g0/0/0  to switch port 1 which is an access port -- vlan 2
    5. connect AP to switch port 2 which is a trunk port , allow vlan 2 and 3
    Now wlan radio is not up (yellow light), please advise any configuration wrong or missed. Thanks a lot in advance.
  • 2.  RE: Campus AP bridge mode not working
    Posted May 19, 2016 12:32 AM
    Do you have cpsec enabled?
  • 3.  RE: Campus AP bridge mode not working
    Posted May 19, 2016 12:35 AM
    Thanks for reply.
    You mean control panel security ? It is disabled. Need to enable it?
  • 4.  RE: Campus AP bridge mode not working
    Posted May 19, 2016 12:37 AM
    Yes. CPSec is required for bridge mode.
  • 5.  RE: Campus AP bridge mode not working
    Posted May 19, 2016 12:39 AM
    thanks a lot , let me try .
