Campus AP learing 2 IP from controller.
Hello frnds,
This is raja and iam very new to this community. I have an issue with my AP.
i have one spare AP which is used in past now its at stock and i have used at some where else on floor now with reconfiguration. But the problem is when i do          "show ap database long | i <apname> "   its showing 2 entries in the output with 2 IPs. THe other ip is used by one more working one..
When i check the both ap port status, its showing diffrent switch ports. Please let me know why its getting like wise..
NOte : please let me know how can i follow-up my posting further process,, because iam new to this communitiy process..
Its my id : rajasekhar33.mca@gmail.com
Thanks in advance,
Raja
Re: Campus AP learing 2 IP from controller.
It looks like you were using the same name for two APs and it might be creating a conflict.
What you could do is run the following clear gab-db wired-ap <mac address of the AP you would like to clear>
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hello Victor,
You are correct, 2 APs are getting conflict with same name.
And after clearing one, issue got fixed. Thnks for your help..
Thnks... :)
