Contributor II
Campus environment Outdoor Heatmap
Greetings,
Im designing one of our campus type environments that has a portion of the site with six buildings.  These six buildings are in two rows of three.  I have my broadband circuit and controler in building five show below. My goal is to present WiFi to all of the outdoor areas between these buildings.  No wifi inside them.  Id like to do this via meshing with no more than one rooftop p-t-p hop from building 5. Then blanket this courtyard/plaza area.
One caveat is my engineers do not want to use MST200.  Can anyone suggest the best way to lay this out?
Thanks in advance!
Re: Campus environment Outdoor Heatmap
Please see the outdoor mesh VRD here:  http://www.arubanetworks.com/vrd/OPPDeployAppNote/ for options on what to do.  There might be something in there that your engineers might want to use.
Frequent Contributor I
There is such tool to do Outdoor projects at Aruba web page https://outdoorplanner.arubanetworks.com - can be useful.
You can do that with MSRs or outdoor APs like (I)AP175 or newest 270 series - BTW it is significantly less expensive than 175 :) I have no idea what is size of your area and what is your user population. Business case as well. All of them could be significant factors for the project.
Many regards,
Marek Krauze, CWNE# 174, ACMX #295, ACDX #356
Something cool, helpful or interesting in my post - click the Kudos Star.
Helped to solve your problem - Click Accept as Solution
Contributor II
I'm still looking for a little help with this one.  I sent this on to my Aruba acount team but always have had good luck on this site.  Having said that, I am new to the board here.  Perhaps I posted it in the wrong place??  Again and  help is very much appreciated.
Mike
Contributor II
OH NO,  I see that this community replied!  I appologies as I had my page open from yesterday and did not refreshh :smileyembarrassed:   Thanks for the links.  I look at these now.
Contributor II
I see that the outdoor planner require Google Earth Pro.  Is this really necessary or will the free version work as well?
It works with standard installation however for commercial use you have to have Pro version.
Contributor II
I ran the Google Earth and input the KMZ files.  The website said something like "processing files",  Then cam back with the message below. I tried this a couple times with the same result..Capture error.GIF
Contributor II
Well I got a bit further using outlook instead of Chrome.  However, I cant get passed the error of " the EIRP must be below the regulatory...."
Contributor II
Okay,  Im giving up on the Aruba externally Hosted Outdoor Planner.  Motorola has a similar program Link Planner that can be downloaded locally and is much easier to figure out.  I wish Aruba had teh same as I cant figure out how to change settings from their default on this.  I would lobe to get any help on this!!  :)   Thanks!
