Frequent Contributor I
Can Aruba AP-325 work with Aruba 3810 switch
Can Aruba AP-325 work with Aruba 3810 Smart rate multi-gigabit ethernet switch? I know that AP-325 come with two ethernet port in order achieve more than 1 gigabit speed and have to connect this two ethernet port to switch. For AP-325, can i just connect one port and also 1 port to the Aruba 3810 smart rate multi-gigabit switch in order to achieve more than 1 gigabit speed?
Re: Can Aruba AP-325 work with Aruba 3810 switch
Hi, the Aruba 325 has two 10/100/1000 ports and can make LACP so its maximum speed will be 2Gbps.
http://www.arubanetworks.com/assets/ds/DS_AP320Series.pdf
If you want an smart-rate access point you will choose the Aruba 330 series that has one smart rate port that can scalate to 5 Gbps and one 10/100/1000 port.
http://www.arubanetworks.com/assets/ds/DS_AP330Series.pdf
If it helps flease add Kudos
