Occasional Contributor I
Can ArubaOS 6.1 detects Rogue APs on wired network?
Recently I've been doing some testing regarding Rogue APs and part of the test is, I try plugging a "Rogue" AP into the wired side of the network, physically, I was able to ping to that AP via the controller. However, the controller itself doesn't detect this rogue AP. I Search throughout the document and online, what I found is AP being detected only wirelessly, I just want to confirm if this can be done? Detecting Rogue through wired side of the network.
Thank in advance
Re: Can ArubaOS 6.1 detects Rogue APs on wired network?
Is there another access point on the same wired subnet as the rogue? That is how it would be detected.
Yes. I tried to plug one in wired, to the network. it was...
Yes. I tried to plug one in wired, to the network. it wasn't appearing on the dashboard rogue
Re: Yes. I tried to plug one in wired, to the network. it was...
Please Open a support case to get this figured out..
