Contributor I
Can I enable AP console debugging from each AP without issues?
Does anyone have knowledge how the loggign storage work on AP? I would assume that console logging isn't stored anywhere and the AP only sends this to the console port?
Is there any drawback to leave console log level as "debugging"?
