Can I have confirmation of an issue with guest provisioning in 6.2.1.2 code?
Hi Guys
Im getting an issue with creating guest accounts on 6.2.1.2 code.
We have numerous browser issues that I understand are fixed in 6.2.1.3 but I can't find confirmation of this one issue.
When creating a new guest user, Im currently unable to select any start or end date past 31/08/13? I can't manually type in an end date for Sept, I also can't select a start date past the end of this month?
I can replicate this issue across multiple browsers
IE9, IE10, latest chrome (29.0.1547.57) and waterfox 18.0.1, switching to Safari makes no difference either.
I was going to move to 6.2.1.3 but I understand that 6.2.1.4 is out, are there release notes for it yet?
Anyone else seeing this issue or can confirm it?
Re: Can I have confirmation of an issue with guest provisioning in 6.2.1.2 code?
I assume you're using the guest provisioning page at ; https://aruba-master:4343/screens/switch/gpp.html
What's the date set to on your controller?
Also are you getting any error message? A screenshot of the error would be ideal :)
Cheers
James
Cheers
James
The issue was around being unable to change the date past the end of the month
It was a bug of some sort as the issue has been resolved by moving to code revision 6.2.1.3, now everything works as expected
