Contributor I
Can Xerox printers be add and how
What do you need to do to put printers on the wireless network
Aruba
Re: Can Xerox printers be add and how
Printers that are WIFI enabled (or any device that is WIFI enabled as a wireless client) can be added to the network.
Are your current printers WIFI enabled as-is ?
Contributor I
yes they came WiFi network ready. I can pull an ip but can not see it in the network. does the SSID have to be set up for a printers?
Aruba
Great to hear they have an IP, that's excellent and 90% the way there :)
Now... what user-role do the printers get on the network under monitoring/clients on the 3400 ?
JF
Contributor I
i will pick this up when on log on at work thank you
