Contributor II
Can not connect AP-275 to controller 7010
Hi every one,
I'm using an AP-275 connect to controller 7010, OS:6.4.2.2. AP connect via port 0/0/0, VLAN 1 on the controller. I did reset both of them many time but  in the "monitor" tab i can't see the AP.
Re: Can not connect AP-275 to controller 7010
Is the controller providing dhcp?
Type "show log system 50" to see if you see any messages on the controller.
Contributor II
I do not see a link light where the 275 is connected to the 7010. Check the cable.
Contributor II
Hi Joseph,
Follow your advice, i got
Jul 3 21:24:40 :307048: <DBUG> |cfgm| Got a message from 8231:5010
Jul 3 21:24:40 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
Jul 3 21:24:40 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
Jul 3 21:24:55 :307048: <DBUG> |cfgm| Got a message from 8231:5010
Jul 3 21:24:55 :307050: <DBUG> |cfgm| Received a IPSEC CFG Message
Jul 3 21:24:55 :307219: <DBUG> |cfgm| Sending the IPSEC Configuration
Jul 3 21:24:58 :307026: <DBUG> |cfgm| master: Refreshing the lms list
Jul 3 21:24:58 :307027: <DBUG> |cfgm| Checking the LMS not responding flag for local 172.16.0.254 flag value is 1, missedHB 0 socketID -1
i have no idea about this, but the LED on the AP is "Green-Flashing"WP_000432.jpg
Can you try to bring up any other access points on this controller?
Contributor II
Yes, i did. We have used it for running demo many times.
Duc
What is providing DHCP for that access  point?
Contributor II
The controller and i can receive dhcp from it with my laptop. This the first time i use AP-275.
Can you tell if the AP-275 receives a DHCP ip address?
If you type "show ap database long", is the AP275 in the table?
