Can someone help me to provide BIll of material, please?
I have requirement for 500 access point and need redundant controller.
Could someone help me to develop the BoM
I also need NMS with redundant system
Kindly help please
Super Contributor II
Re: Can someone help me to provide BIll of material, please?
What is your region? Please contact Aruba SE they will help you in better way.
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Super Contributor I
The skeleton BOM, I am assuming you will be using Licensing Master and buying your own hardware for the Airwave NMS
Option 1
2 X 7210
500 X AP225
1 X LIC-512-AP
1 X LIC-PEFNG-512
1 X LIC-RFP-512
1 X AW-500
1 X AW-500-FR
Option 2
2 X 7220
500 X AP225
1 X LIC-512-AP
1 X LIC-PEFNG-512
1 X LIC-RFP-512
1 X AW-500
1 X AW-500-FR
Normal Guy
Hi Sir,
Thanks for the advise.
Regards / Henrizal Koto
