Contributor II
Can't View Web Categories on Airwave
Hi all,
I've a trouble with airwave running version 8.2.4.1 that is only Web Categories not showed even though i can see it on my controller.
Any one can help me fix this issue?
Many thanks for help
Re: Can't View Web Categories on Airwave
Hey, what ArubaOS version are you running on the controller? Do you see the same issue when using a different browser and what are the browser versions you are running?
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Contributor II
Hi Zalion,
I'm using 7210 controller running 6.5.1.4 version .
I have the same issue with all browser :) even all of them are up to date
Thanks, I've had a look at your ArubaOS version is supported in the same AirWave version which you are running. Can you run the below and confirm all data is being sent to AirWave?
#show mgmt-server message-counters process fw_visibility
Contributor II
Hi Zalion,
Thanks for your response.
This is the ouput, it seem like controller not send App Category because at all line, this value is zero :( but i dont' know why my controller not send App Category to Airwave.
Thanks for the info, what do you have configured under the management server profile?
#show mgmt-server profile [XXXXX]
Contributor II
Hi Zalion,
This is output
show mgmt-server profile default-amp
Mgmt Config profile "default-amp" (Predefined (changed))
Parameter Value
Stats Enabled
Tag Enabled
Sessions Enabled
Monitored Info Disabled
Misc Enabled
Location Enabled
UCC Monitoring Enabled
AirGroup Info Enabled
Inline DHCP stats Enabled
Inline AP stats Enabled
Inline Auth stats Enabled
Inline DNS stats Enabled
