Frequent Contributor I
Can't connect to SSID until AP rebooted
Hi
I had a weird one at a client where we are broadcasting 3 different SSID's - throughout the whole environment we could connect to 2 of the SSID with no problem except the one.
The SSID was broadcasting but no connection could be established with no clear error -- after rebooting the APs we could once again reconnect to the SSID.
Could there be a logical explanation for this?
Re: Can't connect to SSID until AP rebooted
There is no logical reason for that.
You should open a support case.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Collin -  I thought as much...
Unfortunately the Controller has also been rebooted since then so no logs available...
Just thought I'd pose the question anyway.
Moderator
Hendrik
There are a couple of known issues floating around that could manifest as this. What AOS version are you on and what topology (lms+bkup lms? rap? cap? bridge? tunnel?) do you have.
If it happens again, collect the following to help narrow it down faster
show ap remote debug mgmt-frames ap-name <>
show ap tech-support ap-name <>
logging level debugging user-debug <mac of affected client>
show auth-tracebuf
tar logs techsupport
regards
-jeff
Hi - thanks for the advise - will be sure to run the comamnds if it occurs again, so far it hasn't been a problem again.
We are running AOS 6.3.1.8 - All APs are CAP, with primary LMS set(no backup), all connections should be tunnel and controller is local with upstream master controller for vap-config and licensing.
I wonder what may have casued it.
I also encountered this kind of issue.
I am having this issue right now, i'm on a 7205 controller running 325's.  Did you ever find a solution?
How is your issue similar? This thread was opened two years ago.
Hi
Very Old thread, but if memorty serves the issue was related to a bad controller - same issue wasn't seen again but other problems cropted up afterwards (firmware on controller made no diference) restoring backup config onto a replacement controller resolved the issue.
Hi guys,
Similar to the problem that Hendrik experienced. Ssid problem started to live. I have problems using 3 ssid. But using 2 ssid working normally. Any comments on this topic?
Thank you so much.
