Can't connect to SSID until AP rebooted
Hi guys,
Ssid problem started to live. I have problems using 3 ssid. But using 2 ssid working normally. Any comments on this topic?
Thank you so much.
Re: Can't connect to SSID until AP rebooted
Maybe a bit more information would be helpful. Do you use a standalone AP, controller, instant controller? Firmware versions and access point type?
