Can the RAP-2WG be powered with a Power over Ethernet Switch
I am just wondering if my RAP-2WG can be powered on using a power over ethernet switch?  I have lots of network ports I can plug it into, but they don't necessarily all have electrical outlets close enough for the dc power adapter that comes with it.
Thanks!
Re: Can the RAP-2WG be powered with a Power over Ethernet Switch
It is not a PoE device.
Tim Cappalli | Aruba Security
The only "RAP" that can do this is the RAP-108/109
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Thanks very much for the speedy reply!
