Frequent Contributor II
Can we create a mesh link between Aruba MSR and AP175?
Can we creat a mesh link between aruba MSR and AP175?
Aruba
Re: Can we create a mesh link between Aruba MSR and AP175?
No.
Mesh protocol is completely different between ArubaOS and MeshOS.
MeshOS has the Adaptive Wireless Routing L3 solution to enable multi-channel hopping.
ArubaOS is single channel mesh.
-cl
Moderator
Note that you can cable an ArubaOS AP to a MeshOS AP and that will work fine. the ArubaOS AP will use the MeshOS nodes as transport.
Moderator
One more. A MeshOS unit can be configured in client mode. in that state an MeshOS unit behaves just like a simple client device and can connect to any Wi-Fi AP including a ArubaOS device configured for access connections
