Captive Portal Check for Accounting
This option is nowhere to be found under current Controller software. No such menu item, looked for Misc Configuration, and "user roles" is spelt "user rules"  - could this firmware be coprrupt? Where is "Captive Portal Check for Accounting" please?
Model:Aruba3400
Version:6.4.3.7
and if you search on Google this is what I need:
https://gshaw0.wordpress.com/2016/05/25/save-yourself-from-insanity-aruba-captive-portal-radius-accounting/
