Captive Portal Issue
Hello all;
i have a little problem here; is there any way to redirect to the welcome page without entering the login user name and password;
i need clients as soon as they connect to be redirected to a specific website without user and password;
Re: Captive Portal Issue
In order to authenticate without entering the username and password, the "User Login" option can be disabled on the Captive Portal Profile.
There is a way to do this but you need to enable login option and modify the code to not prompt the user for login info and pass the role you want the user to get.  I don't have the code handy but I believe TAC should be able to assist you with this.
Retired Employee
