I have a 3400 pair of controllers in HA. I am trying to install my known CA issued server cert and I'm running into some issues.
Note: based on some of my other installs on standalone controllers, I have appended the intermediate cert and the root CA to the server cert and also uploaded the intermediate and root CA to the controller individually. This was required to make things work before on other controllers.
Once everything was uploaded, I went to admin > general and chose my new cert in the drop down for captive portal. The webserver restarted and everything was good, but the captive portal is still serving the securelogin.arubanetworks.com cert.
I went to the standby node and noticed that the certs weren't there. I tried to upload the server cert there, but I get this:
Error Uploading Certificate: Cert missing private key and failed to find a key generated from a CSR request in the system to match it
The same cert uploaded fine on the primary box.
Can anyone point me in the right direction to correct this?
Thanks!
